Folks... I need Your comments… especially You stress guys and DERs…
I have worked too many places and am now faced with a dilemma I never expected: Interpretation at to exactly what “A” and “B” basis allowables mean… and when/how it is acceptable to use them.
I always used “A” basis values whenever using “specification” metallic materials. NOTE: “spec minimums” invariably match HDBK “A” basis allowables. Note: use of “A” basis allowable-values seems very reasonable assuming relatively “loose” [typical] machining tolerances/finishes… and/or when “standard” sheet metal fabrication/forming is specified.
I reserved the use of “B” basis values when I had the “luxury” of lab-testing [mechanical, chemical] certifications for the EXACT piece of material to be used… and/or for a piece of material that was traceable to a lab-tested/certified lot of material. NOTE: when using “B” Basis allowables, I always used/specified VERY strict manufacturing tolerances and processes… and then analyzed to minimum dimensions/thicknesses.
From MMPDS para 1.4.1.1 regarding “B” basis materials….
“Use of B-Values — The use of B-basis design properties is permitted in design by the Air Force, the Army, the Navy, and the Federal Aviation Administration, subject to certain limitations specified by each agency. Reference should be made to specific requirements of the applicable agency before using B-values in design.”
My dilemma: I got a range of answers from (4) stress analysts on this issue, roughly paraphrased as follows:
I only used “A” basis allowables, because “B” basis values have an unacceptable level of uncertainty and/or risk... and I “assume” worst case manufacturing tolerances/practices will creep in. Besides You can’t get [specify] “genuine “B” basis material.
I always use “A” basis allowables… rarely “B” basis without lab certs.
I always use “A” basis allowables for primary single/critical load-path parts [lugs, spar-caps, critical fittings, etc]: and always use “B” basis values for secondary or redundant/multi-load-path structure.
I always use “B” basis allowables, because the material-vendors are capable of making the raw material to the “higher level of quality” … and why would they [“B” values”] be in the handbooks.
OK… what are Your thoughts on this issue [maybe we will also add “S” basis allowables to discussion, later]?????????????????
Regards, Wil Taylor
Regards, Wil Taylor
