I see your point. My "must" is not lifted from the specification, and your point regarding the actual "should" language in the spec is well taken.
However:
Common-Sense Rule #1: When in doubt, ask. Why risk assuming?
The non-common-sense part: (my
emphasis)
"1.2.1
Classification: The chemical conversion coatings shall be of the following classes,
as specified (see 6.2)"
"6.2
Ordering data: Acquisition documents
should specify the following:"
"b. Class of coating (see 1.2.1)"
and some more of Section 6.3:
"6.3
Interchangeability." ... "Detail drawing of parts of requiring treatment in accordance with this specification
should specify either Class 1A or 3 and any paint finishing systems required to meet the performance desired."
and, finally, followed by the statement you referenced:
"If the coating class is not specified, Class 1A is
recommended."
IMO, this language falls well short of establishing a default, or unless otherwise specified, Class. Personally, I'll take an "as specified" and two "shoulds" over a "recommended" any day. And the "recommended" that you want to follow is in the same Section 6, "non-mandatory", information that you seem to be asking me to "ignore"...
