EireChch
Geotechnical
- Jul 25, 2012
- 1,355
Hi all,
I am working on a project that requires underpinning of a large structure which has settled excessively. We are asked to evaluate the use of micropiles to support the 800mmthk raft. Approx 1000mm of earth fill and a 200mm thk floating slab sit above the raft.
The 168mm dia micropile, and 250mm drill hole are to extend 8m through bad fill and into Siltstone/Limestone. Total length is 13m.
The connection through the raft is the tricky part. I have proposed 3 options and interested to hear your thoughts. It would be great if someone has undertaken Option 3 before with success!!
I believe there are three options, Option 1 which involves breaking out the 200thk slab and earth fill and bolting the micropile to the slab. This requires a considerable amount of work but provides a solid connection.
Option 2 is similar to option 1, only that the plate is located on top of the 200mm thk slab. In theory it should be as sound a connection as option 1 but obviously less practical with 1.2m+ long bolts.
Option 3 is likely the easiest however least robust. We have a 250mm core through the slab, this will leave a smooth hole that isnt great for bonding too! I am aware that there are roughing tools out there but maybe not 250mm in dia. Also, do you think its possible for a epoxy/concrete bond to take 900kN...
I have been in touch with HILTI and they havent helped much.
We are providing several options and it looks like LMG columns will be the preferential one!
