I have a 2700 micromotion xmtr (Foundation Fieldbus) with a T series sensor. The problem is that I need to cut-off the negative readings (Reversed Flow) so it won't affect the process batch station totalizer when the process start. How can I program the Transducer and/or AI1 block so my Delta V system does get those negative reading from the xmtr. Using my 375 communicator I can't program a density cut-off. Any help!
