sudiptoghosh
- Jan 22, 2012
- 11
Alsthom
Micom P923 RELAY in our generator relay panel has tripped on undervoltage as seen from fault records.The relay was set to operate at 80 % voltage with a definite time lag of two seconds.Though it is showing that the relay has tripped on undervoltage in fault records , but when we see the magnitude of the voltage during the fault it is showing around 95 % of the rated voltage (11 kv).So my question is why the relay has tripped on undervoltage when the magnitude of voltage was only 95 % of the rated?.OR is it that the magnitude of volatge during tripping is not being registered correctly during the fault.
