I just started my career as a mechanical research engineer, for a about a month now, and I am required to design a support system for a furnace; people will also walk on the support system so I call it a Mezzanine/Support furnace.
Note: I reviewed the OSHA safety codes for safety on high surfaces 1926.502.
Onto my question, attached is a image of the support system I am creating. The black view is a top view down onto the support system; The blue is a front view; and the red is a side view.
The Beams 2 and 3 are spaced like that to support a 5000 lbf load. I am also assuming a 100lbf/ft^2 load across the entire mezzanine.
I have done deflection calculations, and the max total deflection is around 1/8 of an inch using:
W 12 x 22 (For Beams A and B)
C 10 x 15.2 (For Beams 1, 2, 3, and 4)
Structural Tubing 4 x 4 For the Columns
My question is, how do I determine the angle bracing of the beams; the "angle iron" from the column to the beam?
For the red view, not knowing how to calculate this I just looked at another mezzanine and noticed the support started 1/3 from the top of the column and went the same distance out to the beam. I just followed that same rule with my design, not knowing why!
For the blue view, the plan was to keep things clear under beams 1, 2, 3, and 4, So I didn't want to have the "orange" angle iron braces. Nothing if the "orange" braces were required, but not knowing this I just designed one big one across the back, under beam 1, and re positioned things to work with that...
To restate my question(s):
1. Do I even need angle iron bracing on beams 1, 2, 3, and 4, or even on beams A and B, to the columns? I guess I do not have a good understanding for what the bracing does.
2. How would I calculate the need for such bracing?
***The two reasons why I see the need for the angle bracing are:
1. Another way to transfer the load from the beam to the column(decrease deflection).
2. A way to make the platform more rigid? I do not understand this one, outside of my experience making wooden platforms.
I searched through these forums, the internet, and my engineering text books, but was unable to find an answer to my question. Any help would be welcomed!
Thank you,
-Keigi
Thank you,
-Keigi
