I am designing some equipment that uses some special sized metric threads (103mm). I want the two mating pieces to turn freely by hand (jam nut, adjusting nut, etc). Is there any documentation that defines which tolerance and grade to use when you want a specific outcome (like hole/pin fit tolerances)? I am guessing I want to specify a tolerance/grade for the nut of "6H" and the matching bolt "6g". I believe the standard fit tolerance will work in my situation. I just wasn't sure if I should go larger "6G6g"? I don't want to loose a fit either. Suggestions?
Bill
Bill
