in reply to epoisses.
Where did I say the French invented base 10? All I said was that they made the mistake of using base 10 when they introduced the metric system. They could just as easily taken a harder look at the decimal system and extended it to a duodecimal system with the addition of two more symbols and from there developed the metric system based on that number base. Note that the name metric does NOT imply a decimal base as the Greek word from which it derives means roughly "to measure".
As for the Romans, they did not use a true decimal system as they had symbols for 1 and 5 and all their multiples, that is for integers. For fractions, the Romans used a system of names for fractions in TWELFTHS and many submultiples of these. Why, because it makes more sense to be able to work in a system that allows for exact halves, qaurters AND thirds, something our decimal system does not do nor most other bases suggested as alternatives (binary, octal or hexadecimal.
If using a system of weights and measures that had the most often used measures subdivided into 12ths was so bad, why did it last for so long? History should tell you that if something does not suit the uses for which it is intended, it will tend to fall out of use. But the old 12 base stayed with us in our lengths and weights for hundreds if not one or two thousands of years despite the use of a decimal based number system, and of course are still here today in clocks and compasses.
Note that I am not saying such a system would be easy to implement, but rather it would be a better system.
As for the ease of switching from base 10 to base 12, what is your justification for saying it would be like changing to driving "upside down". Have you done any pilot studies? Have you performed a case study? Have you collected any evidence to support this assertion?
Apart from that, I think you are being very dismissive of people's abilities to effect such a change. After all, the British switched from a system of 12 pennies to the shilling, 20 shillings to the pound (all done while using a decimal number system) to a pure decimal system. And if I'm not mistaken, one nation was able to send men to the moon and bring them back again using systems developed under the US Customary system of measures (with the help I suppose of one or two engineers). I don't think you give people enough credit.
Furthermore, if as was done by the French under Napoleon the system was taught in schools, then in one generation you would have a duodecimally cognizant population. It is only we who have been taught one system that would have difficulty in "unlearning" our decimal times table. As for changing existing systems throughout the world, we now have a positive advantage to assist in that process, something called I think "computers".
Penultimatley, your thought that there would be an "economical advantage for companies to switch to metric (base 10)" would be better than a multitude of different systems is not in question, but that does not invalidate the argument that the use of a base twelve system of numbering and a coherent system of weights and measures based on that number system would be even better than the base 10 system, now erroneously called the metric system. Any number base could be used and still be called a "metric" system.
To conclude, making comments on your beliefs in the suitability of one system versus another is perfectly valid, but they are just that, your unsubstantiated beliefs. When you have completed a full investigation of the pros and cons of different number bases I would be happy to hear your results. And if you are about to ask have I done such a study then the answer is "YES". It would still be a valuable input to see the results of similar investigations by others if they care to provide them as it would serve to point out any flaws, false assumptions or erroneous conclusions in my own work.
