To all
I have an FEM with stress value in an area of interest. Stress is a bit too "high" and is deemed to be the result of the modelling technique used (RBE2,etc).
One does not want to remodel the area as it will most likely create issue. It is known that in that particular area an extra thickness exists due to steel washer.
The question is: Is there a way of "correcting" the predicted stress by taking into account that extra thickness? (using a method than most stress guy will "accept")
I thought of using the ratio (t1/t2)^2 (where t2 is the full "real" thickness)
What I am not sure is the effect of have a "bi-metallic" section (alu + steel)
Any thoughts/ suggestions?
