Hi, I'm Hermess.
I have a question for corrosion rate of cooling water
Generally I assume corrosion rate of cooling water by using Langelier Saturation Index and Ryznar Stability Index.
However, it does not show the exact corrosion rate which is just indicating the proneness and degree of corrosion scale.
Is there any method for calculating corrosion rate numerically?
