I have a 10 house development that we want to have a central meter room, and from then downstream it will be the clients network. The problem I am having is how to provide for a central backup generator but avoid this running through the meters
I also want to ensure that end users (houses) that install PV can grid tie and enjoy feeding power back into the grid (sell it)
The basic attached sketch shows the scheme.
The only way I can see it happening with conventional meters is to have a dedicated change over for each feed, instead of a single bulk one, which is not desirable, is fiddly, and more expensive.
Are there smart meters that will allow this? If so they would need two main functionalities:
1. To have an input for when mains supply is available and when it is, to charge energy use, and when it is not, then not to meter power going through the meters?
2. To allow NET metering?
Many thanks for your input
