bpstruct
- Apr 23, 2008
- 137
If I spec a connection pattern for a metal roof deck, what does that mean for the connection between deck and framing parallel to deck flutes. The pattern covers the connection to perpendicular framing, but not sure how to handle parallel framing. Thinking that I need to spec that separately. I've seen someone else specify a pattern in that direction (36/5). Seems like you would just specify a spacing with framing parallel to deck flutes as the pattern (at least as I understand it) wouldn't make sense in that direction.
