sammybrush
I normally use Patran/Nastran for FE problems but have to complete this in Ansys.
I have imported a surface model from Solidworks via IGES into Ansys and I am having problems gluing them together. Just wondering if anybody would be able to help me?
From the little knowledge I have of Ansys, I believe that to ensure that the mesh is consistent I need to glue the two areas together. The gluing bit I understand (on basic area's) and to refine the mesh I have read that it is better to force the line to have a set element size or number of elements per line, rather than using the smart sizing function. (Which I feel happy with)
I think the problem that I have is that I am trying to glue an area to two other areas without splitting the first, please see attached file
Is there an easy way of splitting the area’s either in Ansys or in Solidworks to try and speed up the creation of the model, as I may have several design iterations to look at?
Many Thanks
Many Thanks
