S
s.p.kerslake@lboro.ac.uk
Guest
I want to create a single stl file from a number of individual stl files with the stls enxt to each other on a common base plane.
I tried to assemble the stls and then merge the assembly file - the facetted geometry was not recognised in the merge - I think you can only merge solids.
So, can I create solids from stls which I can then assemble and then output as an stl?
cheers, Sean
cheers, Sean
