Dear all,
I am working on the coaxial ring-on-ring test. It is a thin circular plate supported on the bottom side with one ring, and loaded with the ring on the upper side. The loading ring has a smaller diameter than the supporting ring.
After applying the load, plate bends.
The problem occurs when the deflection becomes higher than the 0.5 thickness of the plate, due to the non-linearity.
I was wondering does anyone know the equation for the membrane (diaphragm) stress for the mentioned or similar task?
Because the total stress which FEA shows is a sum of the bending stress and the membrane stress. But I would like to know how much is the membrane stress.
I know the equation for the bending stress, but I don't know it for the membrane stress.
Also, some explanation of the membrane stress would be very useful for me, if anyone knows...
Thanks in advance
Peter
Thanks in advance
Peter
