F
fiebigc
Guest
I'm trying to create an analysis in Mechanism where a force is applied to a plate. The plate is attached to a base part by springs.
The plate is assembled by a planar constraint that I've defined limits that will roughly limit the movement of the plate. However that are some rotations that I can't predict and the plate will interfere with the base part and the simulation does not reflect reality.
How can I keep the parts from interfering to make the simulation realistic?
Thanks.
Thanks.
