Mechanical Vapor Recompression
DMcMahan
Chemical
We are considering vapor recompression to upgrade the heat quality of a waste vapor stream so that it would be easier to integrate with existing proceses for heat recovery. I am looking for information on pros and cons of this as well as what issues may prevent this technology from being applicable.
Usually, you'll have to run a centrifugal compressor, with a suction surge drum, to enable this strategy. If the loads are variable, you'll need a variable speed driver, such as a steam turbine. There are the usual mechanical reliability issues with rotating machinery. Also, you'll need to think carefully about anti-surge controls to protect the compressor against very low inlet flows.
The economic justification would require a careful analysis of the net present worth of the installed hardware versus the economic value of the heat recovery, after deducting the operating costs of the compression system.
If you have the vapor at a higher pressure and you are letting it down through a pressure reducing valve anywhere in the system, then you might want to consider a thermocompressor.
If you are interested in this approach see
rmw
Does your plant use a cogen power plant? We installed a two of these and they required 1,500 hp motors. It is only cost effective is the cost of electricity is less than the cost of generating steam. At a cogen facility it probably will not be economical because the extra electrical load will require more steam to be generated.
Like rmw said, you may want to consider thermorecompression.
