Rafael Dos Santos
I have 2 questions regarding mechanical run test (MRT)
1.) What is rated flow? Cause in pump data sheet, there are minimum flow, preferred flow, and operational flow. So which one is used in MRT?
2.) Lets say we have the flow that we want and we run test. If the flow drop below minimum flow like 20 or 30 m3/h, is the test fail? but the vibration monitoring is good.
