Mechanical properties not achieved
Saurav Mukheja
6
Dear All
please help me to provide the specific reason of not getting the desired mechanical properties after HQT of AISI 4130 pipe of 3 inch
parameters taken for HQT
Process Temperature ⁰C Soaking Time (Hrs)
Normalizing 900 2:00
Hardening 860 2:00
Tempering 550 2:30
Results achieved are attached
 https://files.engineering.com/getfile.aspx?folder=572970f6-5289-4cd2-b2c9-0db9863e6b18&file=Mechanical_results.bmp
Dear Saurav,
Check the furnace parameters and also carry out PMI of the material. Your answer might lie there.
Regards.
DHURJATI SEN
What is the pipe wall thickness?
Regards, Wil Taylor
o Trust - But Verify!
In looking at the attached results, I would first follow Dhurjati's suggestion, we got so much different results from trial 1 and 2 (if you used a same temper temperature)!
