Atwerp
- Jun 9, 2006
- 12
I am writing to get clarification on the qualifications of professional mechanical engineers in California.
Under the California Professional Engineers Act, Section 6731.6 and 6734.2 the duties of a mechanical engineer are defined in broad terms. I am looking for further clarification on a specific application. The question is related to soil and groundwater remediation equipment. The remediation equipment typically consists of a series of extraction wells, electrical or pneumatic submersible pumps, underground trenching and conveyance piping, above ground piping, a vapor extraction vacuum blower/ventilator, a vapor thermal/catalytic oxidizer, and water treatment equipment including pumps, particulate and carbon filter vessels, and electronic controls.
It is assumed that the extraction wells will be located and designed by a licensed Civil Engineer or Professional Geologist
The question is can a licensed mechanical engineer do any of the following?
1. Design/specify the in-situ equipment including submersible pumps and trenching and conveyance piping?
2. Design/specify the above ground vapor and water treatment and filter systems.
3. Prepare periodic operations and monitoring reports for the treatment systems
Thank you very much.
