MECHANICA Truss element
  • Thread starter Thread starter Mloew
  • Start date Start date
M
Mloew
Guest
Does anyone know how to create a "truss" element in MECHANICA? It seems to be available in FEM mode via a pull-down menu (containing "beam" and "truss"), but the menu is grayed out in standard MECHANICA mode. I would like to avoid creating beams and then releasing the rotational Degrees of Freedom.
I am using Wildfire 2.0 on Windows.
Thanks in advance.
Matt,
As far as I know, "truss" elements exist only in the FEM Mode. Another
workaround (other than creating beams) would be to use spring
elements in place of one-dimensional truss members.
Matt,
Use beam release to allow the beams to rotate with respect to the end points. Since there is no rotation the beam becomes a truss element.
Luis
Not only is truss elements grayed out but the beam elements end section option is grayed out.
When will ptc look into enabling these two options.
Israr
