Mechanica in WF2
  • Thread starter Thread starter siva5577
  • Start date Start date
S
siva5577
Guest
hi
i am having some sort of connection betwwen the Pro E and Pro mechanica. i am getting some sort of error massage as i have attached below. is there anyone could help me please?
siva
2006-11-05_064723_Mechanica.rar
You are running the analysis in fem mode. you have not installed mechanica properly. All you need to do is run the setup and link mechanica with proe.
Deepak Bhat
Note: You need to install Pro/E after you install Pro/M, so that Pro/E can find Pro/M.
You don't have to reuse the CDs, just run prosetup.exe in the \proeWildfire2.0\bin folder and run through the process. It will just update the config files, rather than do the entire installation again.
