Measuring Resistance 0 -100 Ohm 1
kchaloup
5
I'm trying to design a circuit to measure a resistive probe which has a range from 0 - 90 ohms and provide a linear readout via LEDs. Any suggestions?
Do you want a bunch of single round LEDs in a row, or do you want 7-segment LED readout?
What is the range and accuracy? ( at 0 ohm you must have
absolute error, not % !)
<nbucska@pcperipherals.com>
There will probably beten LEDs. Also, a couple of trip points for alarm conditions.
What is this for? Perhaps it might be easier to buy something that is already available?
I'm interfacing to a resistive fuel probe. The probe varies from 0-90 Ohms depending on how much of the rod is in contact with the fuel.
Hi, can you tell me what values wants to read in the display ?
if you want a reading from 0 to 100 with how many decimals ?
Actually,
I really don't want numeric display. It will just be a row of 10 LEDS.
Simplest solution is to use a microcontroller with an on-board ADC. It can be less than $10.- <nbucska@pcperipherals.com>
how about a four bit ADC and a 4 to 16 demultiplex. set up your range to not use values B-F and you have ten led's plus one value for none of them being lit.
seems simpler than a microcontroller to me, but I prefer solder to software.
there is an IC that provides everything you want!
national semiconductor's LM3915:
The LM3915 is a monolithic integrated circuit that senses analog voltage levels and drives ten LEDs, LCDs or vacuum fluorescent displays, providing a logarithmic 3 dB/step analog display. One pin changes the display from a bar graph to a moving dot display. LED current drive is regulated and programmable, eliminating the need for current limiting resistors. The whole display system can operate from a single supply as low as 3V or as high as 25V.
wow!!!!
isn't it what you desire everyday?
my friends call me the IC MASTER 2002!!!
do u think it's right?
lol
ok now go and enjoy from this IC.
here is it's datasheet:
