kingtutley
It has been a very long time since I graduated and now work in a component dedication lab where I have been asked to verify the characteristics of an op amp. Most of this I can do without too much stress, but I have been unable to find a solution that makes sense to me for measuring open-loop gain.
As I understand it, open-loop gain is the gain of the op amp with input voltages (V+ and V-) equal to zero. The problem, as I understand it, is that the input offset is being amplified and possibly saturating the output.
So, if that's the case, could I not just measure the offset voltage (which is easy enough) then apply that voltage to the inputs in an open loop configuration such that the output voltage is zero (effectively nulling out the offset voltage), then increase the input voltage slightly (1-2 mV) and measure the output voltage again? Would this not give me the open loop gain?
It seems simple to me, but like I said, it's been a very long time since college, and I haven't done this kind of work since then.
Does anyone have any thoughts on this?
