hi buzzly
there are so many chips that measure the frequency directly
and you don't need to setup a microprocessor based circuit to measure frequency
here i introduce the most widely use frequency to voltage converter of the world!!!
it's also very low cost
national semiconductor's LM2907/LM2917 Frequency to Voltage Converter
General Description:
The LM2907, LM2917 series are monolithic frequency to
voltage converters with a high gain op amp/comparator designed
to operate a relay, lamp, or other load when the input
frequency reaches or exceeds a selected rate. The tachometer
uses a charge pump technique and offers frequency
doubling for low ripple, full input protection in two versions
(LM2907-8, LM2917-8) and its output swings to ground for a
zero frequency input.
Advantages:
* Output swings to ground for zero frequency input
* Easy to use; VOUT = fIN * VCC * R1 * C1
* Only one RC network provides frequency doubling
* Zener regulator on chip allows accurate and stable frequency
Applications:
* Over/under speed sensing
* Frequency to voltage conversion (tachometer)
* Speedometers
* Breaker point dwell meters
* Hand-held tachometer
* Speed governors
* Cruise control
* Automotive door lock control
* Clutch control
* Horn control
* Touch or sound switches
and many other user defiend applications!!!!
like your application
if you need more go to
and download it's data sheet.
