jonjose123,
I have some followup comments and questions:
(1) You wrote: "We have an above ground pipeline 6" with design pressure of 140 barg and design temperature of 93 deg c."
You should never base thermal expansion on "Design Temperature". You should always use actual Operating Temperature. You did not say if the piping would be insulated or not. Depending on the geographic location of your project and if not insulated you may need to base your design on Solar adsorption.
Where is this project?
Will the pipe be insulated?
(2) You wrote: In order to make allowance for thermal expansion, expansion loops are proposed. The first choice is to look at the route of the piping and consider the path of travel including the vertical contour of the land. Then develop a piping configuration that fits that route. You may find that you have less problems with expansion just due to the configuration.
What is the configuration of the route?
You wrote: "However, in the handbook of Pipeline Engineering by Henry, there mentions about certain mechanical joints to be used." You state there 5-6" pipe lines. You did not tell us if there will be "Pigging" of these lines. If there will in fact Pigging of these lines that is another reason to use only Loops and not some form of mechanical joint.
(3) You wrote: Has anyone come across with such situation..? . Yes this is not new to the world of piping. There have been many projects over many, many years.
(4) You wrote: Is there any way in which we can avoid expansion loops in the above ground pipelines. Probably not. One issue you have also failed to share is the manner of support and the elevation of support above ground for these 5 lines. You said you would not be burying the piping then so how will you support them and how high above the ground?
Additional Questions:
(5) What is the commodities in these 5 lines?
(6) Where in the world is this project?
(7) Is this project located in a remote location or in or near a populated community?
(8) What is the function, purpose of these lines?
Sometimes its possible to do all the right things and still get bad results
