Measurement of Radial Loading 1
natebott
I am looking for a way to measure radial loading in a bearing on one of our products. Tried searching for general info, but not very helpful. I have litte to no room to modify current assembly to make it easier to get readings. Any help is greatly appreciated.
Echoing Tmoose - and in addition for what purpose and application? Possible to place loading cells or strain gauge (strain gage)?
Texas A&M is doing work with Fiber optic strain gauges for that purpose. Check out the attached paper for more info, and contact my friend Andy Conkey (one of the authors) he is looking for applications....
"Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?" Oddball, "Kelly's Heros" 1970
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
 http://files.engineering.com/getfile.aspx?folder=89208c05-4052-417b-841a-83e9e4c4b242&file=MFPT_57_final.pdf
It is a double row spherical roller bearing in a USAF housing. The reason that their is no room for modification is that these bearings are in a machine in the field, which must maintain the foot to center distance, their is no room to put a gauge between the bearing and mount surfaces. The application is a tub grinder.
This information should be available from the application
engineer who recommended that particular bearing according to the information and loads provided to him. Examining all of the load conditions thrust and moment can then be converted into a radial component based on the angle of the rollers based on the mean of the cup and cone angle.
Stick a matrix of strain gauges on it and then correlate with an FEA model.
Cheers
Greg Locock
...or correlate to known forces applied while unit is stopped.
