Measure perimeter of a Bend part
  • Thread starter Thread starter kmk!
  • Start date Start date
K
kmk!
Guest
hi
does anyone knows how to measure the perimeter of a formed part ( sheet metal bend part) in pro/e in a single selection? at present i am measuring the edges of each side and finally adding them to get the overall perimeter. is it the right way to do?
When you do an Analysis, Measure, Length the box pops up with Length. If you choose Details the Chain option will appear. If you choose Tule-based you can then select Tangent, Partial loop, or Complet loop.
You guys are making me tired ...
Just select the sheetmetal module and lay the part out flat.
You can always delete the sheetmetal features.
Edited by: tosh382
