fmanzanilla
- Jun 30, 2009
- 8
Hello Everyone,
I'm trying to calculate the minimum wall thickness for specially manufactured high pressure pipelines using the "mean diameter formula" (according to manufacturer specs), which to my knowledge is:
Bursting Pressure = 2(Ultimate Tensile Strength)(OD-ID)/(OD+ID)
The thing is, the documentation has an example which does not match at all with my calculations, it speaks of a "minimum K ratio" and the usage of a "M.F.D":
"... GIVING 52.56 TONS/IN2. USING M.F.D. THIS GIVES MINIMUM K RATIO OF 1.637. THUS MAXIMUM BORE IS 1.861 INS AND MINIMUM WALL THICKNESS 0.593 INCHES."
Any idea?
Best Regards.
Any idea?
Best Regards.
