MDX limit values won't stay
  • Thread starter Thread starter gregl
  • Start date Start date
G
gregl
Guest
I have just recently started having a problem with the limit values in mechanism not keeping once i get out of mechanism.
I enter in the values I want, and drag will work fine with those limits. Once I get out of MDX to modify a value or something, and get back in to drag the components, the limit values are gone, and the check-box isn't even checked anymore.
Ever happen to anybody else??
hello
Click Model>Jt Axis Settings
On demand Select Axis Settings, select the axis that you have previous set.
You can see that the system appears you the previous settings of the axis you select
I know it is a drill for someone haven
