All,
What is the best known method to calculate wood deflection for:
• MDF sheet 26 mm thick
• Span 700 mm
• Width 600 mm
• What is the allowable force that can apply?
Thanks in advance.
Aharon
The deflection is dependent on the span, thickness, and loadig. for the physical prop:
See ANSI/A208.2 (2002), Standard for Medium Density Fiberboard. Depending on species and binders (interior or exterior glues) or,
