MCC room
byufan
10
I have a Motor control center ( MCC) that has a dusty atmosphere on the outside which my current a/c is located. What can I put in my MCC room that will not harm the electrcial components , will cool the room and pressurize the room - Help!
My current unit had filters and had be cleaned almost weekly and died... need some other tyep of hvac cooling
what heat gain do you have in the room? this will determine either the size of vent plant or cooling eqpt.
What is the outdoor ambient and waht is the maximum allowable room temp
Friar Tuck of Sherwood
The units proposed for cooling is 5 ton AC unit - can get near 95 in summer for high temperature and max room temperature is around 81 degrees F
