I have a question related to the maximum hydrotest pressure for a natural gas pipeline.
API 5L X52 pipe material, 24” OD with 0.375” wall thickness will be shop hydrotested per API requirements to a hoop stress that is a minimum of 90% SMYS. This value turns out to be an internal pressure of 1462.5 psig.
When this piping is used for a natural gas pipeline, what should the maximum field hydrotest pressure be? I already know that the minimum pressure required by the design codes is 1000 psig, based on Maximum Operating Pressure.
Thanks for your help!
