NoWittyHandle
Geotechnical
What are the economics of using different size fillet welds in steel using shielded metal arc (stick) welding? I am designing the wales (steel beams placed against the excavation wall to support the wall) for an excavation, and the specifications require us to develop the full moment and shear capacity of the beam at splices. The contractor doesn't want to use groove welds because the welds would have to be x-rayed.
I'm guessing that it is usually cheaper to use longer lengths of smaller fillet welds than to use shorter lengths of larger fillet welds. For example, a 3/8" fillet weld might take weld passes, but a 3/4" fillet weld might require seven or eight passes. I don't know if it is even pracitical to use a 3/4" fillet weld, and in the past I have usually kept fillet weld sizes to under 3/8", but this application is going to require tons of welding. Thanks for your responses.
