Maximum Allowable Heat of Hydration and Differential Temperatures in Mass Concrete
concreteworld
SA
Dear All;
Can someone help me locating any International Standard (ACI, ASTM, BS EN, CIRIA) that specifies;
1. MAX ALLOWABLE TEMPERATURE AT THE CORE OF A MASS CONCRETE STRUCTURE (THICKNESS > 1.0 METER)
2. MAX ALLOWABLE DIFFERENTIAL TEMPERATURE BETWEEN THE CORE AND THE SURFACE OF THE MASS CONCRETE STRUCTURE
I tried searching all ACI documents relating to Mass Concrete but they are very general. I believe there is one CIRIA publication that specifies.... Please shed some light.
Thanks in advance
I had researched item 2 earlier this year and found a recommendation that the temperature differential should not exceed 30 degrees F. Can't seem to find the reference for that number.
Ralph
Structures Consulting
Northeast USA
ACI has a document covering thermal and cracking. ACI 207.2R-07. I believe it addresses internal temperature.
ACI 310-10 Section 8 covers mass concrete and answers your two questions.
Try the CIRIA document "Early Thermal Cracking" which is used by practically all UK consultancies when designing for ETC in concrete sections
For the above search for C660 on CIRIA's website. The (now superseded) DMRB document was also used extensively before, and might be worth looking at for a first stab. The calculation method is only a couple of lines compared to the 360 page epic that is the CIRIA guide!
No, thats probably just a preview. The full document is much longer than that. Thinking about it, the guide might not be applicable to regions outside the UK as the temperature differential is a function of the heat of hydration and the atmospheric conditions. The guide is probably well worth a read for qualitive advice at least
Yes, I should have had a look at it. It was only the contents and the introduction.
Doug Jenkins
Interactive Design Services
