maximal radial load on screw 1
trentar
Petroleum
Jul 12, 2011
47
Hallo!
I want to calculate maximal radial load on M8x12 screw (7mm) made of steel grad 12.8. Does there exist any connection (equation) for this. If yes can you show it!
Thanx
j
T=Fr where T is torque, F is the force at radius r.
Cockroach
is "radial" the same as "transverse" (ie shear) ?
does "maximum" load mean allowable ?
"connection" implies a brkt, loaed by torque ? in-plane ?? (in-plane torque would be reacted by shear on the bolt). is the bolt being torqued ??
please restate your question !
