mathlover
Chemical
- Nov 1, 2008
- 2
Hi im trying to understand how to work out the maximum gas velocity in pipework.
The gas and pipework characteristics are -
Biogas - 60% CH4, 40% CO2, traces of NOX, SOX & HCL
Temperature at source is 36C and cools to 6C in winter and 20C in summer because gas passes through a condensate trap and so im assuming the gas will pass through and emerge at same temperature as the water across the seasons.
The pressure at source is about 20 mbar and ideally the same at consumption.
The pipework is 100m total length has 2 90 degree bends, the diameter changes after each bend it goes from 200mm to 300mm to 250mm. Theres a condensate trap at the end of the final leg of pipe. The whole pipeline falls consistently at 2 degrees. There are 2 gate and 2 butterfly valves on the system. Theres 1 gas flow meter and 2 gas pressure switches on the system. The pressure switches dont protrude into the pipeline they have their own 2" take off legs but the gas flow meter is an endress & hauser t mass and im not sure how it fits into the pipe.
Please can someone tell me how to work out the pressure drop and maximum velocities with some working out. Im interested to know what happens if we increase the pressure at source along the system.
Sorry if this is a big problem to work out but youll be advancing me considerably if you can teach me this!
Best regards
Thanks for your help.
Best regards
