JustSomeRoark
Chemical
Gents,
Disclaimer: Process Eng background here with only superficial knowledge of intimate details of valve design: be gentle!
It seems to be common practice amongst my Process Eng colleagues that a full bore, ball on/off valve shall not be open before ensuring that the differential pressure between the upstream and downstream side is lower than 15-30 psi, so a smaller bypass valve is normally provided to allow the pressurisation of the downstream side. Some colleagues argue that this holds for liquid, but some of them consider this should be followed even for gas at, say, 300 psig (i.e. valve should not be open until the downstream side is pressurised to 270-285 psig).
What is the rationale behind this? Is it only aimed to prevent oversizing the actuator? Let's assume the actuator is sized for full pressure rating. Does opening the valve across a large differential pressure (i.e. larger than 15-30 psi) creates high vibration, noise or any other operational upset? We are concerned about erosion of the ball at lower opening (high velocity, high erosion) or damage to the seats.
Any idea where this assumption of low DP across the valve may come from? Is it still valid?
Any feedback on this would be deeply appreciated.
Regards.
Regards.
