API RP520 part I, section 3.3.3.1.3 (page 36) reads:
"In a conventional pressure relief valve application, built-up backpressure should not exceed 10% of the set pressure at 10% allowable overpressure. A higher maximum allowable built-up backpressure may be used for allowable overpressures greater than 10% provided the built-up backpressure does not exceed the allowable overpressure"
It is my interpretation that when we have a PSV for fire case only, I can use a conventional relief valve provided that the built-up backpressure stays below 21% of the set pressure. However, the wording "may be used" in the API 520 sounds quite weak to me.
In this particular case we have a relief valve that reliefs directly to atmosphere.
What is your opinion here?
