ElCidCampeador
I've just received an order for building 1 vessel acc. to ASME VIII Div.1, Stamp U.
It's a very simple vessel, sort of filter, made from pipe and caps, carbon steel.
On the drawing it's written 10 bar as design pressure, and 23 bar as MAWP. Hydrostatic test is according to UG-99(b).
Calcs (given me by the client) were made using design pressure as reference for estimating minimum thickness of components. However, in one page is reported the MAWP as written on the drawing.
My question is: what MAWP do I have to stamp on the nameplate? Usually my AI advises me to put DP=MAWP, but in this case? if I wrote 23 bar on the nameplate, wouldn't this imply that the vessel is verified for an higher pressure, higher than the real one (10 bar)? Do I have to redo calcs at 23 bar?
Thank you
Thank you
