I was wondering if anyone has any experience with mating an Inconel 625 flange to a Duplex S31803 flange? It is a 16" class 300 compact flange connection. The service is production fluids; so a mixture of oil, water and gas. The condition outside the pipe is salt air as this is on an offshore facility. There is no insulation, no heat trace and no coating on the pipe or flanges. I am not concerned with galvanic corrosion with these materials but my concerns are with the differing thermal expansion coefficients of the materials and when the lines heat up during production (~80 Deg C) what affect will it have on the joint and in particular the seal ring. I found the coefficients of linear expansion for Inconel to be around 0.000012 and Duplex S31803 to be 0.000013 which gives a difference of 0.02mm radial expansion on the radius of the duplex over the Inconel. This does not seem like a big amount to me but i am unsure. Are there any special considerations that i need to take into account for the seal ring for this joint? Would it be best to go with a Duplex seal ring over an Inconel one?
any help would be appreciated.
thanks,
jamie
thanks,
jamie
