I'll often bring various parts that were created separately into an assembly file and save the file as a part file to wind up with a single part . I realize you can bring parts into a part file to build the part from various other parts... but preferred the assembly method more because I found it easier use the mating features (at the assembly level) rather than the move command (at the part level).
However I just realized at the part level when you insert a part you also have the option to "mate" the parts ... just like in an assembly. Didn't know this option existed (amazing what you can find out by reading all the options in
the window) before and I'm wondering, does one mating scenerio have a benefit over the other....(whether to mate at the part level or mate at the assembly level and save the final assembly as a part)... if all that makes sense.
Thanks for the suggestions.
