Mates help 1
prooney
84
I have a piece of pipe with one end at an angle and a mating piece of pipe that has the same angle on it and I'm trying to mate the two elliptical faces together.
It won't let me do a concentric mate, what's the best way to mate these tow pieces together. Thanks.
You can add planes or sketches on both ends and mate them together.
A pic of your issue may help.
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
Insert a sketch on the eliptical face, and place a point concentric with the elipse. Do that for each peace, then mate the points. Then just finish up using parallel faces/planes.
Thanks guys, I went into the part file and put a point at the middle of the respective ellipses and then mated the pieces together by the points.
