material_girl
Student
- Jun 30, 2025
- 2
I am attempting to figure out why my explicit model is progressing so slowly. I have tried mass scaling, but it has not helped much. Could someone tell me if my material parameters are correct? My geometry is in mm, so the units I have chosen are:
conductivity: W/mm*k (for example: 0.0298174 at 310 degrees C)
Young's modulus: N/10^6 mm^2 (example: 188053.95 at 310 degrees C)
density: kg/mm^3 (example: 7.64E-06 at 310 degrees C)
specific heat: J/kg*k (example: 610.42 at 310 degrees C)
Thank you
Thank you
