Material to outlive the Giza Pyramids 3
Stephen.Scott
4
Would 316 be the best material for fabricating long-life sculptures?
I want to make artwork ("modern Rosetta Stones") that can survive thousands of years.
Would electroplating, xylan coating, or some other coating be required for locations other than desert environments?
A platinum-iridium allow was chosen for the kilogram standard.
Stainless steel and other materials that require passivation are too finicky. A nickel alloy would likely be best.
Don't make it too valuable, someone will find it and melt it down.
Stone isn't a bad material for a sculpture...
Gold lasts a long time?
Titanium?
Thanks for the feedback. I've worked regularly with 40HRC 718 inconel. What coating would protect it the most from the elements?
Looking at the past, stone may be the best material to work with if the sculptures can remain in a desert. Maybe granite or basalt.
Would titanium work better than something nickel-based?
The main loss of sculpture is by theft. Making it of any metal is just expanding the potential range of thieves.
To get something to last a long time, start a religion of worship for it, but choose the fanatics carefully.
I think it should be possible.
Stainless steel is resistant to corrosion and oxidation.
The durability of stainless steel means that it does not require frequent coating or repair. Perhaps all you need to do is clean and inspect it regularly.
That is the trouble with stainless steel. It requires regular cleaning in order to be corrosion resistant.
I'll start with 2' x 3'ft sculptures. It definitely needs to be workable.
Bronze is one of the substances that will last the longeste exposed to the elements. I dont know if there is a special "sculpture" mix but you might be able to find out yourselve.
--- Best regards, Morten Andersen
well, you could duplicate the method used to form the pyramids. It has been proven that all the interior blocks were formed of geoplymer concrete. See tech papers at <www.geopolymer.org>
Easy to work with and long lasting, what about pure Ni.
There are a number of Cu based alloys that would work well for this.
I might look at NiAlBronze.
If global warming goes as predicted, they'll want to stick with the nickel alloys for temperature resistance....
I'll see myself to the door.
if yellow then NAB
if glittering white then IN625
if pale and ancient look then Monel 400 or 500 whatever
all will last centuries unless a disaster struck.
regards
