Berserk7
- Aug 16, 2010
- 5
Hello everybody
We are designing a box to contain a formulation of 85% of water and 15 % of one water-soluble synthetic polymer.
One step in our process is freezing this formulation from 20 C to -30C at ambient pressure for 2 hours and then it will be warmed at ambient temperature .
I found these facts about the water:
a) The volume of water increase in 9% from its liquid state to a solid one.
b) The water internal pressure produced when the water change its state from liquid to solid is 55MPa
I tried with a box made from ABS , but the ABS box was broken.
I need your help to select the right polymer for this application.
I are thinking in PC and PMMA , I found some LEXAN and PMMA grades for low temperatures -30C,-40C up to -60C .
The manufacture recommended me use PVC, because its a less expensive option.
Also I afraid because in the materials sheet the mechanical properties were taken at room temperature.
Which other parameter I need to check to cover my requirements?
Is it correct, select the material in base of its flexural strength? Select a polymer with flexural strength bigger than 55 MPa of the internal water pressure?
Finally I read that some glues cracking the PC , I need also glue this box with other parts made from PVC (PVC didn’t exposed at low temperatures)
Do you have any suggestion for the glue?
Thank you in advance for your help and advices.
