I would like some opinions on the best choice for materials for use in a valve passing slightly acidic water from an underground mine. I have done lots of research but most info is contradictary, I would like some info from experience if possible. I am only concerned with the corrosive aspects which arise from the acidity.
My opinion is a 360 Brass for the body and 17-4 water hardened SS with an 8 micro finish for the sliding spool member.
The water temp is always under 100F.
This product is cost sensitive and does not need a high safety factor so nothing exotic please.
Thank you!
Don
Thank you!
Don
