Material property limits
UMMET
1
I'm looking to define a sort of "miracle material" for aiding in the frequency analysis of assemblies im developing. The idea is that one could apply a thin film, say .5 mil, over a selected area of a part within the assembly. The film would be as close to infinetely strong and rigid as it could within the bounds of ANSYS computational limits. By being bonded to a part, the film would keep the area its bonded to rigid relative to other portions of the part. I hope to use this as a quick and dirty tool to find the areas that would affect the assemblies the most. The problem is that i have had little success in converging on the limits that ANSYS will accept. Does anyone have any knowledge of these limits, or could someone point me to a source that does?
I'm using ANSYS workbench 8.1
Thanks for your consideration.
making a material too stiff, could lead to wrong results. You should avoid these.
See the command "cerig", it could be helpful to you.
regards
Alex
