First post, so please let me know if there is a more appropriate forum for this question.
I'm designing a component that will be die cast out of an aluminum alloy and need to specify the material to be used along with a variety of properties expected of the cast material.
Through conversations with a supplier (based in India), I've decided on ADC12 (a JIS standard name?) which appears to be equivalent to 383.0 (an ASTM name). I'd like to specify what mechanical properties I want to see in separately cast test specimens (tensile, yield, elongation, hardness) along with chemical composition to verify the material when we get first samples. IS there a standard where I can find this information for the ADC12 material? I've looked at JIS H 5302 which pertains to 'aluminium' alloy castings but this only contains chemical properties.
Is this even the sort of information I should include on the print?
Thanks in advance.
Thanks in advance.
