edison123
- Oct 23, 2002
- 4,508
A 10 Pole, 600 RPM, 50 MW hydro generator was dismantled today.
In between the two poles, two V shaped anchor blocks are fastened to two studs from the rotor rim. These are used to anchor the pole coils against rotating circumferential forces.
In all earlier salient pole machines, I have seen this anchor V block made of non-magnetic materials like aluminium, phosphor bronze or non-magnetic stainless steel.
In this case, these V blocks of magnetic mild steel.
Will not a magnetic V block in the inter-polar space act as a magnetic shunt and create a leakage path between poles ?
I would appreciate your inputs.
